Hi everyone!
Next week I want to look at two different GSX1100g bikes. There apparently is little information about it on the internet.
Are there any specific things I have to look out for? I already found out that the collector is a weak point.
Also, what is the average fuel consuption of a bike like this?
Best regards,
Patrick
Looking for a GSX1100, what to expect, any tips?
Re: Looking for a GSX1100, what to expect, any tips?
Hi Patrick,
welcome to the forum.
We have a detailed list of what is worth to look at if you want to buy a used G. It is in german, I don't know if you can read it. Feel free to ask if you don't understand anything.
Fuel consumption.... well, it depends. With well maintained stock carbs 6 liters are possible and if you use the power, up to 8-10 liters are possible. Worn out carbs can raise the consumption above 10 liters.
Equipped with Bandit carbs it consumes from 5 to 8 liters but then you use every single horse.
Thank you!
I can read german fine (speaking or typing however, less so. )
From what I've read it's quite the gas-guzzler! That's really too bad. :/
It's not fair to call it gas-guzzler, remember when this heavy-weight bike was planned and constructed. At this time the values mentioned above were absolutely normal. In 2003-2004 I owned a GSX1400, even with fuel injection and a lower weight it used to consume nearly the same amount of fuel.
- closey
- Ferryfix & iron butt
- Postcode: 10117
So, did you look at those Gs Patrick..... or not?
Closey
Closey
